Replace Sub flow with TS
oceanbluesky1993
oceanbluesky1993
[ FlexSim 22.2.0 ]
I followed the instruction to build a sub flow program. However, when I tried to replace the sub flow with TS, the operator was stuck at load task.
TS.fsmsub flow.fsm
moehlmann_fe
In the Load (and Unload) activity you refer to the label "box" on the token which does not exist. Weird that this doesn't prompt an error message.
In addition a single load or unload task can only handle one item, hence why a sub flow is necessary to move all items via Process Flow.
And why did you add an A-connection from the Queue to the rack? There are now two parallel control logics that both move the same items.
oceanbluesky1993
I'll try to correct the process, thanks!
