Referencing the Conveyor a Decision Point is on from Process Flow
eamon_o
eamon_o
[ FlexSim 22.2.4 ]
I want to reference the conveyor a DP is placed on from its object process flow. i.e. 'wait for event' current.myConveyor: onExit.
In the past I've solved this by referencing current.centerObjects[1] and just center connecting each DP to its conveyor. This doesn't scale well though since I have to do that manually for each one.
Thanks in advance. See below for the closest I've managed to get so far.
Did some looking into the treenode, and I can access conveyorPoint variable which sees the conveyor the DP is on.
However, when I set a debug label to that value, I don't get something very useful, and can't figure out how to climb back up that path to the StraightConveyor7.
jason_lightfootVL7B4
You use ownerobject() on that value to get to the conveyor.
But the wait for event activity has a conveyor field to allow you to set a token label with that value directly.
If you're using an object flow where the decision point is 'current', the conveyor is simply:
current.as(Conveyor.DecisionPoint).conveyor
eamon_o
Perfect! The code line is exactly what I'm looking for. I'll probably extrapolate this in the future too. Thanks Jason 🙂
