Referencing objects in group in subflow
marianuskick
Message 1 of 8
marianuskick
[ FlexSim 23.2.3 ]
I have a token with a label 'Group' referencing a specific group e.g. "Group1". Now I want to execute a subflow in which I create a token for each object within the group. Each of those tokens should carry a label 'Object' with a reference to a object in the group.
1. If I use token.Group.subnodes.length as Quantity in the Create Tokens activity I get a token for each object but one additional parent token for which I don't have any use. Is there a way not to carry the parent token through the subflow?
2. Object label
2.1 In another project I used Group("Group1") but token.Group does not seem to work. What's the right way to reference?
2.2 How do I defined the index 'x' in the correct way? In the other project I used [tokenIndex] but this seems to be a global index and not a 1,2,3,.. for each new set of tokens in the subflow.
Replies (7)
Message 2 of 8
sebastian_canas9DYX7
Hi @Manus K ,
Assuming you have the reference for the group in a label Group, you could set the Run Sub Flow as the image below:
Perhaps you missed the expression creationRank that returns a numeric value. Here there is a short explanation:
When the [creationRank] part of the expression is evaluated for the first created child token, the creationRank will have a value of 1. When it is evaluated for the second created child token, creationRank will have a value of 2, and so forth.
Message 3 of 8
@Manus K ,
Could you please upload your model or a demo of the logic you built?
Message 4 of 8
marianuskick
Message 5 of 8
marianuskick
Thanks, Sebastian.
For the quantity I'm using token.Group.subnodes.length which seems to work.
The creationRank sounds super useful but I am unable to access the object with token.Group even if I used token.Group[1] for testing purposes. token.Group.subnodes also doesn't work.
Message 6 of 8
@Manus K ,
First, you have an exception because you where using a bad reference in the Delay activities. You were using tokenIndex to reference the row of a Global Table. I created a label called Index in the source, so that you can use token.Index in the delay to reference the row.
Then, I am not sure why the expression I showed you before wasn't working, but I managed to make it worked downcasting the expression to Group as you see here:
Hope this helps! Sorry I cannot send a model back, but I do not have the version you use, hope the screenshots are enough
Message 7 of 8
marianuskick
Thank you! That's working just fine!
What's the reason behind tokenIndex not working? Does that only work directly in activities?
Message 8 of 8
@Manus K ,
As far as I know tokenIndex is an expression that only works in Schedule Source and from 23.2 or 24.0 (don't remember well) in Date-Time Source as well. If you try to use it in any other Process Flow activity it won't work.
