[ FlexSim 21.0.0 ]
I am using the new experimenter to test 2 scenarios using 2 sets(columns) of cycle time data from a global table. The global table is referenced within the processor properties, by referencing the column number in a label on the processor.
In the parameters table, I attempted to create an Option type variable and add the 2 column numbers with On Set > reset Label to select a different column for each scenario.
This approach does not appear to be working in the Experimenter, and I would know if there is a better way to reference and test global table data sets in the options type menu. Thank you for your assistance in advance.
