Reduce speed of transporter based on shift timings
anjunittur123
Message 1 of 12
anjunittur123
[ FlexSim 20.0.10 ]
I have a model in which transporter follows a specific network path and delivers items. For a particular path from network node NN2 to NN3 to NN4, I want to reduce the speed of transporter only in that path depending on the shift timings mentioned in the timetable as per model time .
The speeds of the transporter is given in global table. I want to control the max speed of transporter through global table values.
Also what state to use in the time table so as to control the transporter speed.
How to achieve this? Please help
forklift_speed_reduction_shifttimings.fsm
Replies (11)
Message 2 of 12
sri_vikas_k
Hi @hermione12
Controlling the speed on particular path is easy using the AGV paths. Did you consider that already?
Please refer to the model below how you can control the speed of the agv paths.
toolbox > agv paths> and load and unload speed.
forklift-speed-reduction-shifttimings_SVK.fsm
Message 3 of 12
jason_lightfootVL7B4
You can refer to this post on how to update the AGV speed tables.
Message 4 of 12
anjunittur123
Hi @Sri_vikas K can you please attach the model in 20.0.10 version? I am using the same version version and will be able to view your model
Message 5 of 12
sri_vikas_k
I am so sorry, Unfortunately I do not have that version.
you can refer to the above image to adjust the speed on the path.
forward speed and reverse speed.You can give the numbers directly.
Message 6 of 12
anjunittur123
Thank you but I do not want to control the speed only on particular paths but I want to control the speed based on shift timings using the flexsim simulation clock
for example from 9:00 to 9:30 AM the forklift speed should be 3m/s. After the time period the forklift speed should be updated to 25m/s. how to do this using code?
Message 7 of 12
anjunittur123
Thank you @Jason Lightfoot
But I want to control the transporter speed based on shift timings. how to do that?
Message 8 of 12
moehlmann_fe
Have a label on the network nodes that controls whether they reduce the speed of passing travelers.
Depending on its value, set the maxspeed variable in the On Arrival trigger. Which value of "fromedge" triggers the reduction depends on the order in which the nodes were connected.
Object current = ownerobject(c);
Object traveler = param(1);
int toedge = param(2); //the number of the edge that the traveler is going to next
int fromedge = param(3); // the number of the edge the traveler came from
if(fromedge == 1 && current.ReduceSpeed == 1)
    traveler.setVariable("maxspeed", Table("GlobalTable1")[1][2]);
else
    traveler.setVariable("maxspeed", Table("GlobalTable1")[1][1]);
Switch the label value in the Down/Resume Function of the time table to switch the behaviour on and off.
forklift-speed-reduction-shifttimings_1.fsm
Message 9 of 12
anjunittur123
Thank you @Felix Möhlmann
For the same network node path, I want to control the speed during specific timings such as from 9:00 to 9:30 AM the speed reduction should happen, after that time period the forklift speed should be updated to original speed. In my model, model time starts at 8:00 AM.
In this case, where to include code and what logic to be used?
Message 10 of 12
moehlmann_fe
The logic above to build to allow that. In the time marked as downtime in the time table, the speed will stay the same (non-reduced) and during the "active" time in the time table it will be reduced when reaching the edge nodes from one of the queues.
forklift-speed-reduction-shifttimings_2.fsm
Message 11 of 12
Sorry - I saw Sri's comment and answered about that - but you're not using AGVs.
Message 12 of 12
anjunittur123
Thank you @Felix Möhlmann it is perfect
