Reasons for no Connection to the OPC servers?
sebastian_hemmannE3JAU
[ FlexSim 18.1.1 ]
Hey, attached
you see a screenshot in which the System console Shows an
exception: getAvailableServers() error. Could not browse OPC Servers. Service may not be installed or could not connect to remote ip.
As you can see, it´s a test with an Express Version of FlexSim. The Client tryed this out some weeks ago on one machine and everything worked fine. Now it seems to be the only Computer in the company this works on.
So what could we have done wrong? What could be a reasons for this "Exception"?
What could be settings that we´ve set right on the working Computer?
matt_long
Did you install 64-bit FlexSim? We've found an issue with trying to browse for available servers (at least locally) when using 64-bit FlexSim. It only seems to be an issue with browsing, not connecting to servers or browsing their tags. We're currently working with Softing OPC who developed the OPC toolkit that FlexSim uses to try and solve this issue. For now, the solution is either to use 32-bit FlexSim (uninstall and reinstall FlexSim), or to get the path/name of the OPC server from a 32-bit FlexSim and copy it into the Server field in the 64-bit version.
matt_long
We've just discovered what the issue is and have pushed a fix to the latest bug fix of the 2018 Update 1 release. Not sure when that will be released..
philboboADSK
The issue is with some dependencies that are installed with OPC.
The next bugfix release (18.1.2) should install those dependencies correctly.
In the meantime, you should be able to fix it right now with 18.1.1 if you follow these steps to fix it:
  1. Download both OPC_Core_Components_Redistributable_x86.msi and OPC_Core_Components_Redistributable_x64.msi from https://cloud.flexsim.com/index.php/s/UGDCrYLSohWRNu3
  2. Uninstall any versions of FlexSim 18.1 that are installed.
  3. Install OPC_Core_Components_Redistributable_x86.msi first.
  4. Then install OPC_Core_Components_Redistributable_x64.msi.
  5. Finally, reinstall FlexSim 18.1.1.
That should fix this error. Let us know whether or not you are still having troubles with it.
Phil BoBo
Sr. Manager, Software Development
