read item label at sink
nicole_s2
nicole_s2
[ FlexSim 17.1.6 ]
Hi all,
I programmed my source that all the generated items are counted ongoing and all the respective numbers are written on the labels.
Now I would like my sink to read aout the labels on the items with the respective ongoing numbers.
Is anybody able to tell me which command I have to run that the sink reads out the number on the label to me?
The Version is 17.1.2
Thank you very much!
Best regards,
Nicole
ongoing-number.fsm
jeff_nordgren
@Nicole S2,
I'm not sure what you mean when you say you want the sink to read out the number on the label to you. What exactly does that mean? The place you would put code to do anything concerned with the flowitem before it is destroyed by the sink would be in the OnEntry trigger of the sink.
Thanks.
ralf_gruber
@Nicole S2,
is this question referring to this post:
https://answers.flexsim.com/questions/63941/ongoing-number-on-items.html?childToView=64005#comment-6...?
So you want a table with the label values at the source and another one at the sink?
Please describe more detailed, what you want to have at the end.
joshua_s
This model will output the label both in a table and in the output console. All code was added in the triggers of the Sink.18283-ongoing-number.fsm
