Re-evaluate the backorder when the slot label is updated
ozawa_shinya
ozawa_shinya
[ FlexSim 23.0.12 ]
I think findSlot also evaluates backorders like a list, but is it possible to customize the timing? For example, can I re-evaluate the backorder when the slot label is updated? The attached model does not re-evaluate, so the slot is not found.
Thanks in advance.StorageSystemBackOrder.fsm
moehlmann_fe
Observer
Observer
I am not aware of a function to manually re-evaluate the Find Slot query. This only happens when an item exits a slot in any storage object.
What you could try is to release any waiting tokens back into the activity after the label value has changed.
reeval-findslot-fm.fsm
ozawa_shinya
Tank you for your information. I modified my model based on your advice.StorageSystemBackOrderv2.fsm
