"Using Global Lookup Table" not working
lucas_braga1
Message 1 of 10
lucas_braga1
[ FlexSim 7.5.4 ]
I have a processor, a queue and a sink. I want the sink to pull a certain quantity of items (that is already written on a Global Table cell) of the queue. I'm using the "Global Lookup Table" option, but even when the cell number is 0, all items go straight to the sink.
So is there some option/code that can do what I'm trying to do (receive/pull a exact quantity of items)? It doesn't necessarily has to be a sink...
Replies (9)
Message 2 of 10
jing_chen
"the cell number is 0" means Sendtoport trigger of the queue will return 0, while return 0 in this trigger means "First Available", and it still send items to downstream.
If you do not want to send items, you will make the cell number be "-1".
Message 3 of 10
lucas_braga1
For example, the tablecell is now 2, 4 items were processed at total... but all of them went straight to the Sink. I don't understand
Message 4 of 10
philboboADSK
Please post a model showing the issue. We can't explain what is happening unless we can duplicate the issue.
Phil BoBo
Sr. Manager, Software Development
Message 5 of 10
lucas_braga1
model-global-lookup.fsm Don't understand how the function works, the quantity of items that go to the Sink is the not the same as the number on the table cell.
Message 6 of 10
philboboADSK
The "By Global Table Lookup" pick option in the Pull Strategy is looking up what port to pull from out of a table. It doesn't control the quantity of items to pull.
The return value of the Pull Strategy is which input port to receive the next item from.
From the User Manual documentation on the Pull Strategy trigger:
"Pull Strategy - This parameter is only visible if "Pull" is checked. This picklist returns the input port number connected to the object that the next flowitem is to be pulled from. This field is evaluated only on reset of the model and when the pulling object becomes ready to receive its next flowitem."
Phil BoBo
Message 7 of 10
lucas_braga1
Oh, got it. Thanks for explaning this pick option 🙂
So there's some option/code that can do what I'm trying to do (receive/pull a exact quantity of items)? It doesn't necessarily has to be a sink...
Message 8 of 10
philboboADSK
Close your input after you've received a certain number of objects:
Phil BoBo
Message 9 of 10
joerg_vogel_HsH
If you set an item to be hold (return -1), you have to release this item explicitly by releaseitem(obj item, port). obj item is a reference to the item to release.
Message 10 of 10
lucas_braga1
Thank you! 🙂
