[ FlexSim 23.2.2 ]
Can you please explain why the pulled id is "no path" for this token. Thanks
[ FlexSim 23.2.2 ]
Hi Dharshini,
If the values you're pushing to the list are tokens, it's probably because the token pulled has already entered the "Sink" activity before this delay ends and therefore it doesn't exist anymore. However, it's very hard to tell without seeing how your logic is built, so if that's not the case you should attach your model (or a dummy replicating this logic).
TUT 5 iNV FLOW.fsmPlease find the model attached
In this case, what you're missing is defining the partition from where the token must pull.
Hi, thanks, how can I make the operators perform a teamlift on this Splitflow.fsm
Look for coordinated tasks on this site or in the tutorials. If you can't find what you need then ask a new queston.
Hi @Dharshini, was one of Paula LG's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
