Queue with a second Control Point in AGV path?
ray_f1
ray_f1
[ FlexSim 18.1.2 ]
I am looking for a way to add a second AGV control point to a single Queue. When I add a second control point the AGV will pick from the first selected point and never from the second one. This was asked a couple of versions ago and I do not understand that answer. I am currently using 2018 Update 1.
joshua_s
This is because it finds the closest CP to the AGV based no the shortest path it needs to take. Here is an example model showing 2 AGV Systems with the same connections, just the CPs spaced out differently. agvclosestcp.fsm
ray_f1
Thank you for your quick response. That is greatly appreciated. Unfortunately the next control point in my path is the closest one but is passes it up. I am using the generic AGV process flow. Should i try this with a dispatcher instead? I included a pic of the area i am talking about.queue-with-2-control-points.png
joshua_s
@Ray Farkas
Sorry for overlooking your comment, Did you get it to wokr or are you still looking for a solution?
