[ FlexSim 19.0.0 ]
In doing tutorial AGV Tutorial 4 I encountered a problem with the Queues connected to upper floor Location CPs, in that the flow items get created but just sit there and are never picked up by an AGV.
The AGVs are on the loop as they correctly drop off other items at the sinks on those floors. When I put a Processor in between a Queue and the Location CP, it works. When I looked at the details of the flow items, it seems the only label that gets assigned is the LoadType on item creation; the 3 labels normally assigned on Output when the item is assigned to the AGVWork list are never assigned.
I couldn't see what I had done wrong (always my first assumption...) but then I loaded the simulation in 2018 and it worked perfectly. Included here is my model of the tutorial including the Processor I added on one of the Queues on an upper floor to check my logic.
Thank you!
