Queue do not recycle flowitems?
doris_c
doris_c
[ FlexSim 19.0.0 ]
Hellow, everybody
i'm try Use queue instead of sink
but Item returns when loading point
I want items stacked in the queue and my program is consists of processfloor . please help me
thanks, for your kind
1_2.fsm
gokulakrishnan_k2
@Doris C you are using same token.item, again and again, the downstream flow so the item won't stay in the queue.
doris_c
thanks Gokulakrishnan Kandasamy but i can't understand If possible, please explain it in a photo. thanks
gokulakrishnan_k2
@Doris C After unloading in the final queue again same token moved to next unloading sequence step. Actually it's looped again and again. You can try to create process based on item entry in the process.
doris_c
Thanks Gokulakrishnan Kandasamy Thank you for solving the problem 🙂
Ben_WilsonADSK
Hi @Doris C, was Gokulakrishnan Kandasamy's answer helpful? If so, please click the red "Accept" button on their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
