Question on "Move Item via AGV" picklist option
kart_ik
kart_ik
[ FlexSim 17.0.8 ]
PFA : Is there any way to make item stay on the object instead of moving on to the control point when using "Move Item via AGV" picklist option. I want the input of the object( in this case ,Processor // please have a look to the attached model) to be blocked until an AGV comes and collects the item.
jing_chen
Hi! @Nadavalur Sarath Kumar
You can comment “moveobject()” command out in "Move Item via AGV" picklist option, like the pic below.
kart_ik
Thanks a lot for the quick reply. It seems to solve my problem.
kart_ik
agv.png@jing.chen . Thank you for your reply. I have some other similar problem. When I use AGV template for AGV movement and pushing items to the list, in this case how can I make item stay in the object until AGV picks it up rather than moving item to the pickup point.
I find the block in the AGV template that actually do this function . How can I make changes to this block to safely do make the item stay in the object until AGV collects it without affecting any other things in the model ?
jing_chen
Try to delete this two activity(as shown below).
