question floor storage
wangxu_zp
wangxu_zp
[ FlexSim 22.2.0 ]
How can I use a script language to set parameters such as bay, level, etc. when performing batch generation of floor storage through a script?
moehlmann_fe
Number and sizes of bays/levels/slots can be set using function_s() with the function names below.
function_s(rack, "setNumBays", num);
function_s(rack, "setNumLevels", num); function_s(rack, "setNumSlots", num); function_s(rack, "setBaySize", size); function_s(rack, "setLevelSize", size); function_s(rack, "setSlotSize", size);
You can find these and some others by exploring the structure/tree of the dimension edit window of a rack object.
Note that forward compatability is not guaranteed for the function_s expressions.
wangxu_zp
谢谢您的回答
jason_lightfootVL7B4
You can set these properties using rack.setProperty(). The dimensional properties are listed here along with a description of the values required and the use of arrays in setting mixed values.
