[ FlexSim 22.0.0 ]
Task sequence A is preempt only and another task sequence B is no preempt.
When the agv is executing B and has finish the task, the token runed into another task activity which is belong to anonther agv, so the token didnot come to the agv's finish task sequence activity.
At the same time, task sequence B called the agv and due to its preempt property, the agv went to execute B, when it finished B's task, as usul the A should be finished, but it failed.
What makes this scene special is that orange travel activity.
How can I make the agv be away from the allcated idle state? preemptQuestionV2022.0.fsm
