Quality Time
Quality Time
frederic_t
Quality Time
frederic_t
[ FlexSim 19.0.3 ]
I create a product and this product is sent to a rack. The product can be use after a quality time for example : 2 days. After these 2 days, the product is free and it can be use by an operator for a process.
I would like to know how it is possible to use the time creation to free the product in order to use it.
SCHamoen
@Frederic T On the rack you will find the "Minimum Dwell Time" trigger. This is exactly what you need. in that trigger you can define a time that a product has to be in the rack before it can be send on.
frederic_t
Thank you for the answer
juliette_c
@steven.hamoen Is it possible to define different "minimum dwell Time" in function of item of the product ?
SCHamoen
@Juliette C Yes ofcourse. If your item has a label containing the dwelltime you can refer to that label directly in the By Expression option. Otherwise you can use the Values By Case option or you look it up in a global table or you write your own piece of code.
