Push to list only when object leaves the top level of a flowrack?
Gust_Flex
Gust_Flex
[ FlexSim 23.1.2 ]
Hello, is it possible to push to a global list (with the properties of the flowrack) only when the object on the top level leaves?
this is what I do now, but I want to push only when an object leaves the top level (level 3)
joerg_vogel_HsH
May I suggest you take a look into a trigger source code editor. You find a parchment roll icon next to a trigger. Each trigger has got a default header. Declared local variables are available to all templates you can choose. Based on them you are capable to edit a logical expression.
Try triggers which are related to components of a rack.
Or you click on the arrow down icon next to a condition edit field of push to a list template and choose an appropriate expression which you can edit.
