Push Global Table Values To List?
rajankur6494
rajankur6494
[ FlexSim 20.0.10 ]
Hi Team,
I have to push all table values to list along with column name.
What is the easiest way to do it?
Thank you!
Matthew_Gillespie
The easiest way is to use the List.push() method, for example, this line will push the value in the first cell to the list:
List("MyList").push(Table("MyTable")[1][1])
If you want a more specific answer you'll have to explain what you're trying to do.
Matthew Gillespie
FlexSim Software Developer
rajankur6494
Hi @Matthew Gillespie,
Thanks for your answer!
Can you help me with this model if I want to push values with column name in list?
Thank you!
11. PustTableValueToList.fsm
Matthew_Gillespie
@Ankur A3 I'm not sure what you mean by that. Do you want to push a string that has the column name and the cell value? Like "Resource:DN"? Can you give me some examples?
Matthew Gillespie
rajankur6494
Ok @Matthew Gillespie. Sure.
I am able to do push values now. I am facing some other issue with model. I will post it separately.
Thanks for your help!
