[ FlexSim 20.0.9 ]
Hello! My aim is to create a tote with a unique orderNumber label and match each tote with the trays that possess the corresponding SKU_IDs. I can get this to function if I have each unique ORDER_ID matching one SKU_ID. Where I am struggling is to get a tote with an ORDER_ID that requires multiple SKU_IDs to pull all of these trays into the system, not just one.
For example, when I have the first order enter the system, a tote is created with a label orderNumber equal to 1. An additional label is assigned to identify the SKU_requested based on a Global table lookup in ORDER_MASTER. This token is then pushed to the 'Active order list'. On the other hand, trays are created for each of the SKU_IDs in the Global table INVENTORY_MASTER and these tokens are stored in the 'Storage list' with the labels for each SKU_ID. The process entitled 'Pulling trays into the system' is intending to pull any active order in the system and match it with the corresponding SKU_IDs, visually transferring them into the 'Pull_Into_System' queue in the 3D model.
I have created a small model to work-through the logic I am trying to implement in my main model, and have attached it below. Please let me know if you have any ideas or insights that may help me work-through this issue. Thank you in advance for your help!
