Pull the specified data from the list
wie_k
wie_k
[ FlexSim 23.1.2 ]
I would like to know how and how I should issue the SQL syntax in order to grab a specific transaction in plural tokens
In my idea, when Transport1 arrives at the designated location, the token will be pushed into the deliverCarts list, and at this time the pickstation will grab the current arrival (the box transported by transport1) from the list and process the token
For example, the first transported object is type 16, which is the fourth token in the Pull from finish of the pickstation process. How can I trigger it to make it enter the next stage?
a_star_test_分區.fsm
moehlmann_fe
I currently see two reasons why the logic is not working:
1. In the pickstation process flow the tokens pull from list partitions defined by the instance objects (stations). So you also have to push the transporter token to those partitions for them to be able to be pulled.
2. The tokens need to pull 2 entries from the list but currently only a single token is ever pushed to the list.
julie_weller
Hi @Proxima, was Felix's answer helpful? If so, please click the "Accept" button at the bottom of the answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
