Pull Strategy with CODE for Demand
sofia_izquierdo
sofia_izquierdo
Hello everyone.
We are using codification to fill racks with pallets, but now we are having trouble with the codification (code) that has to be used for the pull strategy. I mean we need help for taking the pallets out from the racks.
PS. We need to implement exponencial distributions for the pull strategy.
I will be very thankful if someone can help us.
Sofia.
sam_stubbsYXX86
I'm not sure I understand what you mean you are using "codification" to push/pull items from the racks. Is this something you could use an item list for? You could create a label on the items, and field in the list properties that would allow you to "pull" items from the list based on a query.
If you could set up the list pull as a "Pull from List" activity in process flow, this would allow you to generate tokens based on the distribution rate at which you want the pulls to occur, and then they could pull from the global item list you created. Is this along the lines of what you're looking for?
