Pull strategy and shortest processing time
ireneusz_kaczmar
ireneusz_kaczmar
[ FlexSim 17.0.10 ]
The model is working in pull strategy, priority is shortest processing time for 5 items. Process time for elements is: (1+1,5+2,5+2+3)/5=20/5=4,0. AvgStaytime in queue should be 4.0, but in this mdel is 4.1s why ??? Someone has any idea ? spt.fsm
jeff_nordgren
@Ireneusz Kaczmar
I'm not sure where you are getting your numbers from. Here is how they should be calculated.
Enter Q		Exit Q	Time in Q
1		3	2
1.5		4	2.5
2		5.5	3.5
2.5		8	5.5
3		10	7
Total			20.5
20.5/5 = 4.1
So it appears to me that FlexSim is calculating the Avg. Staytime of flowitems in the queue correctly.
ireneusz_kaczmar
Thx for your support Jeff. In my first approach I was thinking that sum creation time and suma processing time 20/5 flowitems = 4s. In my first model processing sequence of flow items was wrong. Flow sequence was 1,2,3,4,5, but for STP should be 1,2,4,3,5 for flowitems. I rebuilt my model I compared FIFO vs. SPT now is correct. I send good model spt_ok.
Could you explain me how did you get your numbers Exit Q and Time in Q, flexsim has especialy report or something else? For new case I added new label (EDD Earliest due date). Can anyone verify if the flow is good? spt-ok.fsm
