@joey
For some reason, I was not able to get my revision of your model to work in FlexSim 17.1.6. I was able to get the exact same model to work in the current version (19.0.2) without any problems. There must have been some sort of bug in version 17.1.6. And because it does work in the current FlexSim version, I'm not going to try to "fix" the problem in 17.1.6 that has obviously been fixed in the current version. I suggest that you upgrade your version to the current version. To view the attached model, you could download the current trial version so that you can see that it is working. But you really need to upgrade to the current version.
If you have any problems or questions, please let us know.
Thanks.
0909090-jn2.fsm
