Property table change bay size value
begona_espineira
begona_espineira
[ FlexSim 24.0.2 ]
when changing the values of bay size, level size, slot size, in the Property Table I need to do it 1 to 1 because it opens the rack interface itself and for some reason it does not change automatically in all. Am I doing something wrong or is it not possible to modify these values in the property tables in another way? I think it would be great if you could also edit these values in the property table without having to make a code for it. Thank you!
jason_lightfoot_adsk
You can select multiple values and use the Apply to All button:
Or better still - use templates for your racks - but check that the NumBays override is removed on the instances.
begona_espineira
Hi Jason, thank you! Yes for the NumBays I was able to use the button apply to all, but not for the NumLevels, NumSlots, baySize, LevelSize, BaySize... The tab of the Edit Dimensions is opened when you click in the column header and I was confused. I checked again and I foun the button apply to all here in the right bottom of the tab:
It seems that is works well like that.
Thank you as well for your proposition of using the templates.
Jeanette_Fullmer
Hi @Begoña Espiñeira, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
