Programming an operator and a multi level trolley [still need help]
maciej_kotlicki
maciej_kotlicki
[ FlexSim 17.1.0 ]
How to make an operator put boxes on a multi level trolley (one that has several shelves) on a shelf? For example he starts from the bottom. Fills it with boxes until it's full and than starts with the second one etc. Additionally he makes a different animation depending on which shelf is he packing/unpacking. I know how to make animations, just don't know how to program this.
blandine_de_romemont
I have made this example earlier operator-and-racks.fsm, but I did not do animation on it. Hope this helps for a start.
sam_stubbsYXX86
I'm not sure about the animations, but you could just have your "trolley" have several tote objects in it at the beginning, and load items not directly into the task executer or trolley itself but into the totes inside the trolley based on whatever loading criteria you have. You could edit the tote flow item's look as well if you wanted it to look more like a rack inside of a trolley. Would something like this work?
Alternatively you can look inside the pallet object in your flow item bin, and click on the packing method to get the code on how FlexSim stacks boxes on pallets. You could create a similar "packing method" on a pallet in your trolley, but edit it so that the z location of items would be based on whatever criteria you had. I'm not sure if this would work for your situation either though.
maciej_kotlicki
I guess I could edit the packing method and set z location. Could you help a little bit on that? I'm new when it comes to writing code.
When it comes to the animation I guess I could add the startanimation command. Just would have to somehow start the right animation depending on the z location.
