programmatically toggle network view modes
sung_kim
sung_kim
[ FlexSim 16.0.1 ]
When you X-click a network node, the network cycles through different view modes, allowing you to show or hide the network.
Is there a way I can select a different network view mode through code?
Ben_WilsonADSK
function_s(netnode, "setViewMode", viewmode);
For the parameters:
  • netnode is a reference to one of the network nodes in your model
  • "setViewMode" shouldn't change. It specifies the function to run
  • viewmode is an integer 1, 2 or 3, for the different view modes show all, show edges, show nothing
sung_kim
Thank you, @Ben Wilson!
It works perfectly for my network node! Awesome!!
