Processor Time with Tolerance Time
TalHzf
TalHzf
[ FlexSim 22.2.0 ]
Hi All,
I want to ask if I can with Flexsim define the Time on a processor with a tolerance (for example +5% or -5% for the already given time.
Thank you all.
jason_lightfoot_adsk
double ptime=50;
return uniform(0.95*ptime,1.05*ptime);
If you can't assume uniform, you'll need some other distribution for which you'll need to figure out the parameters.
TalHzf
Thank you @Jason Lightfoot ,
But I don't know where to enter your instructions.
In the process time trigger of the processor.
Don't enter it exactly as it is - you need to assign ptime the value you need - which could be item based.
TalHzf
In the trigger i find On setup Finish, Process finish, on Entry??
Which one should I choose
Thank you
Jeanette_Fullmer
I believe @Jason Lightfoot intended for you to use the process time field.
TalHzf
Hi @Jeanette F ,
Thank you I understand it.
