Processor Problem for Nth Item
samueltan5550
samueltan5550
Morning Sir/Miss, I have problem dealing with the processor. I want to set the processor to have the First setup time at 30 seconds and others setup time at 1 seconds.But it turns out the setup time remains 30 seconds. Thanks for viewing my problem and appreciate if you share the solution^_^
samueltan5550
need help thanks
FelixMoehlmann
The option you are using gives a different time for every Nth item/in an interval of N. If that interval is 1, this applies to all items.
To have a non-zero setup time for a single item only, you can use "Values By Case" with the input statistic of the processor as the case function.
