Processor manual assist by operator in daily basis
kitkat87
kitkat87
[ FlexSim 23.2.0 ]
Hi all expert,
I had group of processor, each of them have range of percentage for daily manual assist(scheduled down) by operator
For an example:
Processor A will have random 6-10% manual assist by operator on daily basis
Processor B will have random 3-7% manual assist by operator on daily basis
Processor C will have random 1-5% manual assist by operator on daily basis
May I know which function that should I use? I tried MTBF but unable to get the results that I want
moehlmann_fe
What about the MTBF did not work out? It features an option for the "Down Function" to call an operator to the affected object who then 'repairs' the machine for the duration determined in the Down Time field.
You would have to choose fitting distributions to arrive at the down time percentages mentioned in your post. Which ones to use specifically you will have to determine yourself based on the breakdown profile (many short failures, few long failures) you want to achieve.
https://docs.flexsim.com/en/24.0/Reference/Tools/AgentSystem/ProximityBehavior/ProximityBehavior.htm...
You could also pre-determine the downtimes at the start of each day to fall within the mentioned ranges. For example in a regular user event that writes the values to a global table. The MTBF would then read those values instead of determining its own random values.
Jeanette_Fullmer
Hi @kitkat87,
Thank you for contributing to our community! We couldn't identify a maintained license or subscription linked to your account.
You may need to update your profile information to identify yourself as a license owner or their associate. Check out our article for how to ensure you receive timely support. If you update your profile comment back to let us know - we'll adjust the priority of your post accordingly.
If your current license is expired, please contact your local distributor to renew.
