[ FlexSim 18.2.2 ]
I have a model that uses 2 different systems to stop processors.
1) A time table makes the processor stop for maintenace based on the model time.
2) A process flow uses a global table to make the processor stop (breakdown) based on the number of units processed.
On some occasions, a certain sequence of these stops make a processor to keep its "maintenance" state when it resumes. This creates a completely irrelevant state bar.
I believe that the problem is related to the fact that the processor is stopped by two different times, and that it was already resumed once when it has to be resumed the second time. It may be basic but I can't figure out how to fix this issue.
Here attached is a simplified model that illustrate this problem.
Thank you for your help.
cusersavillega2desktoptime-tableglobal-table.fsm
