Process Flow Utilization Statistics Using Statistics Collector?
rajankur6494
rajankur6494
[ FlexSim 21.0.10 ]
Hi Team,
I want to create utilization for 3 machines having process flow activity reference using statistics collector. I am using enumerate object to create activity names as row value and average content as column event.
I think there is syntax issue. Can you help to know the issue?
05.07.2022_ProcessFlow_Statistics.fsm
Thank you!
moehlmann_fe
When using enumerate rows, the update timing of the measured value (utilization) should be set to 'When the value is accessed'. Trying to update the value when the row is created (on reset) is causing the error message.
'getactivity()' expects the name of the activity as a string as the second parameter. The row value is a treenode, so you have to add '.name' to get the activity's name.
rajankur6494
JordanLJohnson
Agreed, thanks @Felix Möhlmann, this is a great answer. Minor detail: if data.rowValue is an activity, then you don't need to use the getactivity() command. In the popup, you can just specify data.rowValue .
Jordan Johnson
Principal Software Engineer
