Process Flow: Using TS to create preempt task
tongsw
Message 1 of 10
tongsw
[ FlexSim 18.1.0 ]
I have a question about creating a preempt task in process flow. I use Create TS to create a preempt task. But the result is that this task isn't a preempt task. The details are shown below.
demov201810.fsm
Replies (9)
Message 2 of 10
isaac_l1
@tong
Could you clarify what you are trying to achieve? What do you want the operator to do? Thank you
Message 3 of 10
tongsw
I just want to insert a preempt task( a utilized task) when the operator is implementing a unload task. Thanks for your reply.
Message 4 of 10
sam_stubbsYXX86
We're still not entirely sure what you mean by you want a "preempt task." Can you clarify further? You want the operator to go into a Utilize state during the unloading, is this what you're trying to do?
Message 5 of 10
tongsw
yes,this is what I want. thanks
Message 6 of 10
isaac_l1
Instead of using a preempt task you would want to use a Delay for the operator to go into a Utilize state during the unloading. Here is an example. I have also attached a model below.
12572-delay-utilize-operator.pngdelay-utilize-operator-model.fsm
Message 7 of 10
isaac_l1
@tong
Does this answer your question?
Message 8 of 10
tongsw
Thanks for your reply. Actually, This unload task includ a travel task .I want insert a preempt task(a unlited task) during the operator on the way to unload.
Message 9 of 10
jing_chen
Hi @tong
Change Executer/Task Sequence to "token.taskSequence"
Message 10 of 10
tongsw
The problem has been solved. Thanks very much.
