Process Flow error
Process Flow error
Cristian505
Process Flow error
Cristian505
[ FlexSim 22.2.1 ]
I have a problem in my process flow logic, when I play my simulation I get this error, Error de process flow .jpg , attached to the image you can see the error I get, I think it is because the process flow is not recognizing the "involved 1" item, which is part of the 3d model. Does any one know how to fix this problem please ?
moehlmann_fe
The item reference in a Load activity is invalid. Check that the label you use there correctly points to an item.
andrew_o2
Hi @Cristian505, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
