Process Flow encountering error on synchronized activity after preemption
poeychingneo
Observer Observer
poeychingneo
Observer
Observer
[ FlexSim 19.0.2 ]
I have encountered an error of "Error: Invalid Connector In at "Synchronize" in "ProcessFlow"." This error happens when the token that was originally in the Synchronize activity was being "Restored Context" after being preempted away. Could anyone share on any possible reason that may cause such an error?
FYI. I am not able to duplicate the issue with a small model.
Attached are some captured pics to show the state before preemption happens
, after preemption happens
and the error message
thanks in advance.
joshua_s
@pc neo
Would you be able to share your model, you can even make a new private question if it is confidential material.
poeychingneo
Observer
Observer
thank you. I've posted the model as a private question. 🙂
Matthew_Gillespie
This is a bug. In your model you're releasing the token and then that token moves through more connectors after being released. This situation isn't being handled correctly. I'll add the issue to the dev list.
A workaround for your model is to not move the token after it's been released. I did this by converting your flow of assign label activities into a single custom code activity.
Matthew Gillespie
FlexSim Software Developer
