Process Flow Combiner with one input port
sebastien_b49
sebastien_b49
[ FlexSim 19.0.0 ]
Hello !
I am trying to build a process flow to model a combiner that only uses one input port. It should just wait that a specific amount of flowitems enter it to destroy all of the items but one (join). This amount is defined in the machine's label.
The problem I have is that I do not know how to collect several flowitems in the process flow without multiplying the amount of Wait for Event. Is there a way to do so, like a "Wait for X item" kind of activity ?
If it helps, please find my trial model attachedcombiner-process-flow.fsm
Best regards,
sebastian_hemmannE3JAU
Hi @Sebastian The Activity you are looking for is the "Batch" Activity.
For the Task you are looking for I would use the "Batch" that releases as many tokens as it has to collect.
As soon as all tokens leave the "Batch" I would use a Zone / Resource to allow only one token to move the item on (On Max Wait timer = 0 time -> go another way).
With this you only have to go sure, that the first token needs a time to be moved.
17253-combiner-process-flow-1.fsm
sebastien_b49
Hi @sebastian.hemmann !
thank you for submitting your model.
I tried using a batch already but it never receives flow item. I created a basicFR, wrote the Process Flow (Event trigger source + Batch + Delay + Release item), added the basicFr in the model and assigned the Process Flow with the instance of the basicFR in the model.
Then when I connect the BasicFR to the output of a processor and launch the simulation, no flow items enters the basicFR and the batch in the Process Flow inside my basicFR does not collect anything.
Could you explain me what I am doing wrong ?
By the way is there a way to link a Process Flow to all the instances of a BasicFR in a model before they are dropped in the model ?
joerg_vogel_HsH
receiveitem and releaseitem are essential for a basic FR. You have to call these commands.
joerg_vogel_HsH
A Process Flow FR Processor can join items and then start processing. The Process Flow Fixed Resource template is enhanced.
procees-flow-processor-join.fsm
sebastien_b49
Thank you ! I saw a similar post but could not understand how it could help me. Now I got it thanks to both of you @sebastian.hemmann and @Jörg Vogel ! Have a nice weekend !
