Process flow- assigning tokens for boxes in tote
jakub_f
jakub_f
[ FlexSim 20.2.3 ]
I need help with process flow. I created process flow, in which the operator carries the boxes from the tote and carries them to the station but the sequence does not repeat.
I suspect the problem is the lack of tokens but I don't know what to add or change.
XYZ.fsm
mitregatomasz90
Hi Jakub
First advice do not assign boxes in totes to label. Refer to them by tote in Yours model it will be (token.pak1.first and token.pak2.first). Then when You unload them refer to them by operator (token.resource.first) and finally when you destroy them by shape (Model.find("Shape453").first). Put the whole process in sub flow and repeat 5 times.
I attach model with changes. Powodzenia 🙂
xyz.fsm
jakub_f
Dziękuję bardzo !!!
