proces flow problem
proces flow problem
a9080109
Observer Observer
Message 1 of 8
proces flow problem
a9080109
Observer
Observer
[ FlexSim 23.0.0 ]
展開.fsmI want to know how I can make my model work, and I also want to understand what token.processor means. What is the significance of wait for event in the model
Replies (7)
Message 2 of 8
joerg_vogel_HsH
token.processor is a label at a token called by string “processor”.
Message 3 of 8
a9080109
Observer
Observer
But when I set the resource to a machine, do I need other settings?
Message 4 of 8
joerg_vogel_HsH
@mark zhen, you did not assign any value to a label called "Processor" in this Process, where the error occurs. You use "token.Processor" to read a value for a quantity to acquire resources.
If you used it in a different process flow block beside where this error is happening, it has not got any meaning for this process.
Each Process Flow block creates an own scope for residing tokens in it. A process flow consists of activitis and blocked activities, which are in some way connected by black bold lines with arrows.
Message 5 of 8
jason_lightfootVL7B4
Please arrange your activities to show you have some care and thought for the process.
This is not good:
This is better:
Message 6 of 8
a9080109
Observer
Observer
@Felix Möhlmann 展開.fsmThe process I have sorted out now is roughly as follows. What I want to do is to assign personnel to perform processing, and when the personnel perform processing, each machine will have a corresponding status to generate a Gantt chart of personnel and machines.
Message 7 of 8
This is standard functionality - please do the tutorials.
Message 8 of 8
a9080109
Observer
Observer
I found relevant teaching. Thank you.
