Problems with Load in task sequence
h255290
h255290
I have a event trigger source that when an object gets into the first floor storage, starts the task sequence. But, while doing the task, I have to use the load to pick up an object in a second floor storage. The way I'm doing is not working because it ends up picking up the object in the first floor storage. Does anyone know how to make it work the way I need? I'm new to using process flow.
s1125413
You have to check the specified object in the event trigger source. I only built a simple model based on your demonstration in version 2023 for your reference.
h255290
Thank you for taking your time! What I need is that the trigger is when a box enter the first floor storage, the forklift picks up another item in the other floor storage, not in the first. Do you know how I can do that?
s1125413
From your description, you need to make sure there are items in the storage on the other floor. When an item enters the first-floor storage, it seems that a message is sent to call the forklift to pick up another item from the storage on the other floor.
h255290
It worked!!! thank you so much
lcdiazM6QFX
I have tried this example, but I think there is a problem, the items sometimes come back to the first position from where they were picked up. This happenst to me also in my simulations, I cannnot find a solution. Please, help.
