Problems with Labels
lukas_ker00
lukas_ker00
FlexSim v25.2
when starting my model in FlexSim I get the error message:
time: 0.000000 exception: FlexScript exception: WIDTH is not a valid column name for Global Table "ReferenceTable" at MODEL:/Tools/ProcessFlow/ProcessFlow/Create Object: Item>labels/2/2 at line 0
time: 0.000000 exception: Unable to set LastWidth to NULL; using 0.300 instead
The message states that the column "WIDTH" does not exist in the Table and therefore can't be used for labeling items in my ProcessFlow ("Create Object"). But the Table "ReferenceTable" contains the column "WIDTH". I also checked for case sensivity. What did I miss?
The model can be found in the attachements.
FelixMoehlmann
The column header has whitespace at the end.
lukas_ker00
Yes, thanks 👍. I totally missed that.
