problem_with_the_motion_parths_robot
felixwarczek
Observer Observer
felixwarczek
Observer
Observer
Hello everyone,
I’m currently working on a model with a robot in FlexSim and I’m facing a few issues.
I created a new individual motion path so that the robot moves into a waiting position. However, the movement looks strange and not as expected.
Additionally, my second Load and Unload activities are not working properly. The robot either performs unexpected movements or does not handle the item correctly.
I’m not sure if the issue is related to the motion path settings, the task sequence configuration, or something in the Process Flow.
If anyone has an idea what might be causing this, I would really appreciate your help.
Thank you in advance!
FelixMoehlmann
The robot is missing a path from the wait/reset position back to the machine for the second load action.
When I tried to add one the logic that chooses the path to use behaved weirdly. Not sure if there is a bug present. You can do the load and unload task through a Custom Task activity as well though and force the robot to use a specific path, if you run into the same problem.
lauri_barnhart
Hello, @felixwarczek,
Did the information provided by @FelixMoehlmann help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
