Problem with setting breakpoints
patrick_zweekhorst
patrick_zweekhorst
[ FlexSim 21.2.3 ]
When you open some code, set a break point and then open another code window to set a second breakpoint the first breakpoint will disappear. This used to work fine in older versions. Is this intentionally or a small bug? You can see the situation in the gif below:
Patrick
philboboADSK
This is a bug. I'll add a case to the dev list.
Phil BoBo
Sr. Manager, Software Development
sara_b5
Hi @Phil BoBo, has this problem been solved? I found it also in FlexSim version 23.0.3.
philboboADSK
This bug is still on the development list. It has not been fixed yet.
It is a minor visual bug; the breakpoint still works correctly.
Phil BoBo
sara_b5
Thanks for your answer! I agree that this is a visual bug. It also seems to me, however, that the first breakpoint does not work:
philboboADSK
When you pushed OK on the code window in your gif, it deleted the breakpoint by applying the now-visually-gone breakpoint state of that window. If you had closed, canceled, or left the window open, the breakpoint would have still been there.
Phil BoBo
