Problem with moving items from queues to entryTransfer
mohamed_slama
mohamed_slama
[ FlexSim 18.0.1 ]
firsttrybufferv1000.fsmHello everybody,
In my model, I'm trying to create a conveyor in a double direction by superimposing 2 conveyors,
I think that I Implemented a correct logic. My Problem is that when I call the activity " Send to back conveyor" for the second time at 20s, the items are correctly moved to the queues but are not moving to the entryTransfer which they are connected with.
Can someone please helps me to find out what is wrong in my model ?
jeff_nordgren
bumped
matt_long
Did you know that you can listen to a Group of object's events? If you add your decision points to a group, the Event Triggered Source can listen to the OnArrival of all of the objects in the group simultaneously. Then you don't need some many copied activities.
You could also use a Decision Point type where the On Arrival trigger has the same logic as your custom codes. Then set all of the decision points to use that Decision Point Type.
isaac_l1
@Mohamed Slama
Did this help answer your question?
