Problem with forobjecttreeunder and destroyobject
li_ze1
li_ze1
[ FlexSim 16.0.1 ]
I want to delete networknodes ,but the following code does't work.
forobjecttreeunder(model())
	if (comparetext(getnodename(node(">classes/1", a)),"NetworkNode"))
	destroyobject(a);
marco_baccalaro
Use this code:
for (int i = content(model); i > 1; i--)
	if (isclasstype(rank(model,i),CLASSTYPE_NETWORKNODE))
		destroyobject(rank(model,i));
li_ze1
That's right and I got a new command "isclasstype", Thank you very much.
But I want to know why it does't work with "forobjecttreeunder"?
marco_baccalaro
Because while it is searching into the tree you destroy an object and it doesn't work anymore. So, using it, you destroy only the first network node found.
