[ FlexSim 23.0.6 ]
I was working on a model with a high number of AGVs using accumulation paths, where I need to know the distance remaining for the AGVs to complete a mission in order to assign missions optimally.
When working on this, I have noticed that on multiple occasions the value returned by the distancetotravel() function is infinite, making it impossible to efficiently assign missions.
I have created a small model where I replicate this case, where it is observed that it returns an infinite value while it is blocked by accumulation at a crosspaths, this occurs at second 435 approximately.
Is this a bug? I understood that the distancetotravel() function is simply a distance check between the point where a traveler is and a destination in the same network, regardless of what happens in the network.
Thanks in advance.
23.0 DistanceToTravel Problem.fsm
