Problem with combiner quantity
talia_z
talia_z
[ FlexSim 17.2.5 ]
Hello! My combiner's target quantity randomly changes after each run. I have my Combiner1 set to a "Target Quantity" of 8 from "Input Port 2". This number has changed to a random number anywhere from 1 to 75. I have investigated my model to ensure there are no messages being sent to the combiner, but can't figure out why this is happening. I would greatly appreciate any advice you may share.
bottle-unloader-process-v6.fsm
jeff_nordgren
@Talia Z,
In your OnExit code in the "Unload truck" object, on the getvarnode code line, you are setting the Target Quantity of Combiner1 to the length of the subnodes of the "Broken down dunnage" object. My guess is that this is not what you are wanting/expecting to happen. I'm not sure what to suggest to fix it because I don't know what is happening in your model. But this is the line of code that is causing the Target Quantity in Combiner1 to change. And if you do mean to change the target quantity, this isn't the way it should be done anyway.
Thanks.
bottle-unloader-process-v6-1-jn1.fsm
