problem in animation run if I change person properties.
akhil_raja_rao_k
akhil_raja_rao_k
[ FlexSim 20.0.0 ]
I'm doing a process flow in which a person carries a bag from a Queue and drops at another queue then walks to another destination. All the animations were running good, but when I change the person's properties to male operator from male staff, the animations were not running as when the person properties were kept at male staff.
tanner_p
Hi @Akhil raja rao K,
Would you be willing to upload your model or an example model of what you're working with? That will help us understand what you're doing.
It's important to note that Operators (Task Executers) are fundamentally different from Male Staff (Flow Items) and they carry different animations and properties that may affect how they behave in the Process Flow. If you set up the Process Flow for a Male Staff, you should continue to use the Male Staff, but change the skin to look like an operator rather than change the object type to be the Operator Task Executer. Hopefully this helps.
braydn_t
@Akhil raja rao K
Did this answer help you? If so, could you please accept it? If not, could you let us know what else we can do to help you? Thanks!
akhil_raja_rao_k
yes, understood, many thanks @tanner.p
