Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 17.2.5 ]
I would like to set a Zone partition constraint to use different values depending on the partition that we are in. It is possible using the exception rows as in the image below. However, the values are fixed. Is it possible to make them into FlexScript so that one could use e.g. a value defined in a macro as with the main limit?
Or would it be possible to get the token/partition already in the limit code so that one could write the exception rules there?
Thank you!
Kind regards,
Axel
