Picking Station
Picking Station
Zubair
Picking Station
Zubair
[ FlexSim 23.1.1 ]
dimension X4.fsmpie-evo-cam-01-0001.pngI want to make conveyor simulation I want an picking station which work as tilt totes of higher level and operator pick objects from tote and place in lower level toteI use sperator but it is not work like that
jason_lightfoot_adsk
You should place decision points on the conveyor for the tote positions. Sent the totes to those and have a process flow that detects their arrival and has the operator perform the pick when the two totes involved in a transfer are present.
But you're a long way off from that stage - as far as I can tell you have no items in the model.
Also - just build one Aisle and one pick station to test its operation before building your whole model. Then you can just copy/past a working one. Alternatively if you must develop the whole model at once you can create a template of the picking station and have instances of that inherit the changes you make as you improve the 'master' object.
Hi @Meteor, was our answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
