It is a problem of subnodes hierarchy. I call pallets of items in a rack “containers”. The items in a container I call “products”. I do this declaration, because both are items in the scope of FlexSim.
Racks in FlexSim 19.1.2 are Fixed Resources and not part of a warehouse. All your racks store just containers.
You better transfer any product data into labels at the container. You can interrogate any data of any object in your Modell, but it is a bit difficult to build all relative paths to those objects and items. It is easier to store relevant data at the container and update the data there if any change happens.
if you need any products out of the rack you can transfer the container or the product. The transporter needs only the reference to the object to carry.
You get an order request for an attribute specified product. If you have all needed data reside inside the container, you can query your rack subnodes for this data. The result will not be the product but a container in your rack. You have to identify the cell by level and bay
rackgetlevelofitem
https://docs.flexsim.com/en/19.1/Reference/CodingInFlexSim/CommandReference/CommandGroups.html#rackg...
rackgetbayofitem
If you want to load only a product and not the whole container, you have to address the product inside the container. Typically you remove the last product of the hierarchy of subnodes from the container.
It is structured in code literally:
- reference of container point last subnode
Object product = container.last;
Other references to products are first or subnodes[num rank]. num rank is any valid order number of all products in your container. The number 1 is equal to first.
stacked containers are also a hierarchy of rack cell items. Once you have identified a container, in fact you queried a item in the rack, you know the level and bay of the cell. Then you need the rank of the container and the total content of containers in the cell.
rank of container in cell
you can create a reference or pointer to each container by bay, level and rank
As you said, if the container of ordered products is not last then you have to address in consecutive order any above container and transfer them until you can load the desired container.
